Non linear heat source using UDF
1 Attachment(s)
Hi everybody,
I am trying to solve a steady state heat transfer problem in an axisymmetric solid region, but I need to add the source term "sinh(T)" so that the heat conduction equation has the form of that in the image I attached to this post. The source only depends on the local temperature. To add the term I built this UDF using a DEFINE_SOURCE macro, but when running the simulation, I get exactly the same result as if there were no "sinh(T)" term. ************************************************** ** UDF that adds heat source term sinh(temp) and derivative to solid ************************************************** *** #include "udf.h" #include "math.h" DEFINE_SOURCE(sinh_heat_source, cell, thread, dS, eqn) { double source; double temp = C_T(cell, thread); source = sinh(temp); dS[eqn] = cosh(temp); return source; } Could you please let me know if you find any mistake in the code? Thank you |
