[Sponsors] | |||||
Export Data Access Macross. Plot Second-Order Pressure. |
Brian
Rep Power: 0 ![]() |
Hello community! I'm new in Fluent and I want to know if what I'm trying to do is possible and if it is, how can I do it.
I need to plot the Interstitial Fluid Pressure for a solid tumor surrounded by interstitial fluid being subjected to focused ultrasound waves (both high intensity and low intensity). I have an UDF for first-order parameters defined like this: DEFINE_SOURCE(msource,c,t,dS,eqn) { real source; source = (CSV * (VFP - C_P(c, t) - SIG * (PIV-PIF))) - (CSL * (C_P(c, t) - ILP)); dSn[eqn] = 0.0; return source; } (One for tumor tissue and another for normal tissue). C_P(c, t) stands for the data access macros that accesses the pressure in a cell designated by the pointer c contained in the cell thread designated by the pointer t. The variables CSV, CSL, VFP, SIG, PIV, PIF, ILP are all constant-valued parameters that may take on different values over different cell-threads. I need to calculate the second-order pressure for this problem, which is a function of C_P(c, t) and the fluid velocity as follows < > = a *< > + b *< >Being a and b constants, the first-order fluid velocity and the second-order pressure.My attempt to solve this, due to my lack of experience with Fluent is import the calculated values of C_P(c, t) and then write another UDF for the second-order pressure as above and finally import that UDF to solve for . Also I want the instantaneous values of over stationary surfaces, not just the mean-valued terms.Is this possible? Is there another way to do something like this? I'm looking forward to your answers! Thank you very much for your time. My best regards! Brian. |
#2 | |
Lucky
Rep Power: 68 ![]() ![]() ![]() |
This could even be done with a custom-field-function instead of a UDF route, but custom-field-functions can't be run in parallel unless you have the latest v18.
When you are in a steady solver x-velocity is the mean velocity. When you are in a transient solver x-velocity is the instantaneous velocity and the mean variables have a new name. |
Brian
Thank you very much!
Do you know of any tutorial that explain how to do that? |
| Tags |
| data access macross, fluent, second-order pressure |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Utility to export field data | tbrycekelly | OpenFOAM Post-Processing | 1 | November 23, 2024 08:48 |
| Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 06:35 |
| CFX Solver stopped with error when requested for backup during solver running | Mfaizan | CFX | 40 | May 13, 2016 07:50 |
| Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
| pressure gradient term in low speed flow | Atit Koonsrisuk | Main CFD Forum | 2 | January 10, 2002 11:52 |
