Periodic Repeats Interface not showing consistent coupling |
May 24, 2017, 05:36 |
Alex
Rep Power: 12 |
Hey Guys,
I set up a rotor/stator problem with translating sliding mesh motion. The rotor and stator region have periodic boundaries on their top and bottom sides respectively. The interface region is set up with the periodic repeats option. Though the solution is converging, it shows that the coupling of the periodic repeats interface is not consistent. I have translated the interface region geometry to show what is going on. The not-overlapping region of the interface is not consistent with the following stator part of the mesh (see picture). Anybody knows if there is something I could have overlooked? Cheers Alex http://imgur.com/a/CkbFc Last edited by Kina; May 24, 2017 at 05:37. Reason: adding picture |
May 29, 2017, 03:41 |
Alex
Rep Power: 12 |
anybody with an idea what could have gone wrong? still working on the case with no reasonable solution
May 29, 2017, 05:28 |
Kal-El
Rep Power: 9 |
please send a picture of the mesh in that same area.
May 29, 2017, 06:02 |
Alex
Rep Power: 12 |
This is the mesh in the exact area. As the simulation works with different codes, it was my thought that the periodic repeats interface may not work as I want it to.
Cheers Alex |
May 29, 2017, 06:44 |
Kal-El
Rep Power: 9 |
Mesh size is quite different in the problematic area. Try adapting the larger cells near the interface.
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Using Interface for Periodic Boundaries | Shamoon Jamshed | FLUENT | 6 | February 14, 2016 02:26 |
Periodic Interface | Magnoli | CFX | 0 | November 7, 2007 07:51 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
