September 4, 2017, 13:05 |
How to calculate Nusselt Number in Fluent
Ramakant Gadhewal
Location: Chemical Engineering,National Institute of Technology,Warangal (T.S.),India
Rep Power: 16 |
Dear All
I need your help how to solve the Nuseelt number formula to plot GRAPH between length vs Nusselt number.I do not how to calculate DTm/DX, Ts, and Tm. Thank you Regards Ramakant |
September 5, 2017, 04:45 |
Cees Haringa
FLUENT can give you the wall nusselt number directly; you can visualize it with contour plots or find it under reports. DO note that this is the local Nusselt number, you have to area-average it if you want a value representing a larger wall section.
September 5, 2017, 05:42 |
#3 | |
Ramakant Gadhewal
Rep Power: 16 |
Hi.. Thank you i am trying to go this...How can i do this area-average in surface integral ? |
September 5, 2017, 07:06 |
Cees Haringa
reports -> surface integrals
September 5, 2017, 07:51 |
Ramakant Gadhewal
Rep Power: 16 |
February 13, 2018, 02:21 |
hi
pankaj sharma
Rep Power: 10 |
hey i am working on the same stuff, but unable to figure the accurate nusselt no. please let me know if you have a solution.
March 27, 2018, 08:32 |
#7 | |
vidyadhar
Rep Power: 9 |
I have an array of conductive fins attached to a constant temperature hot plate losing heat to surroundings. Here, the temperature of the fin varies along its length as it loses heat to surroundings. I want to plot variation of Nu along the length of one fin. Then to calculate local Nu along the length of the fin, what are the available options in Fluent. Does the "Plot-->WallFluxes--->Surface Nusselt Number" gives the right values? Length of the base plate which is many times larger than that of the fin is taken as reference value for length. Thanks in advance! |
February 26, 2019, 08:37 |
#8 | |
Oula
Rep Power: 10 |
Can Fluent give Nu as a single value?. Another thing, I can't find "Surface Nusselt Number" in the surface integral. I did a transient simulation do you think that I need to set this parameter in advance before commencing the solution? Your help will be greatly appreciated |
February 26, 2019, 09:56 |
#9 | |
Oula
Rep Power: 10 |
Did you manage to solve your problem? can you share your experience here? Did you saved data of "Wall Fluxes" & "Surface Nusselt Number" first before starting the solution? eagerly awaiting your reply |
February 26, 2019, 11:47 |
#10 |
Oula
Rep Power: 10 |
Hi again
I just got this information and I would like to share it here for any future visitors To get access to the Surface Nusselt Number you need to have the following set: 1) In the Run Calculation Task Page (where you set the number of iterations), ensure you toggle on the Data Sampling for Steady State Statistics under the Options section (there is an equivalent one for Transient simulations). 2) When plotting values, you will find the variable under Unsteady Wall Statistics and then Mean Surface Nusselt Number. If Data Sampling for Time Statistics is enabled in the Run Calculation Task Page, ANSYS Fluent gathers data for time statistics while performing the simulation. The statistics that ANSYS Fluent collects at each sampling interval (which consists of the mean and the root-mean-square-error (RMSE) values) can be postprocessed by selecting Unsteady Statistics... in any of the postprocessing dialog boxes. If you select Unsteady Wall Statistics... in any of the postprocessing dialog boxes, you can view wall statistics such as Mean Pressure Coefficient, Mean Wall Shear Stress, Mean X-Wall Shear Stress, Mean Y-Wall Shear Stress, Mean Z-Wall Shear Stress, Mean Skin Friction Coefficient, Mean Surface Heat Flux, Mean Surface Heat Transfer Coef., Mean Surface Nusselt Number, Mean Surface Stanton Number. Important: When including or excluding statistics on variables, it is recommended that you re-initialize the flow statistics. |
May 8, 2019, 04:00 |
#11 |
vidyadhar
Rep Power: 9 |
Hi Oula,
I have done like this Local heat transfer coefficients can be plotted on any surface of interest using Plot--->Wall Fluxes-->surface heat transfer coefficient. Regards, vidyadhar |
calculate friction factor & nusselt number | soheil1991 | FLUENT | 3 | March 11, 2017 09:30 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Extracting Average Nusselt Number of a vertical Solar Chimney directly from Fluent | yomilayeni | FLUENT | 11 | September 23, 2015 16:12 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
