How to calculate node temperatures from cell temperatures?
Old   May 27, 2017, 07:21
Default How to calculate node temperatures from cell temperatures?
h0rst is on a distinguished road
Hello everybody,
I want to export the temperature field from Ansys Fluent to Ansys Classic for further calculations.
The problem is:
Ansys Fluent calculates cell temperatures whereas Ansys Classic uses node temperatures.
Does anyone knows an approach how to export/use the element temperatures in this case or have an idea how to solve this issue?
Best regards
h0rst
h0rst is offline   Reply With Quote
Old   May 27, 2017, 20:59
Svetlana Tkachenko
Светлана is on a distinguished road
In some solvers you can tell them whether they use cell-based or node-based approach. An example of such solver setting is discussed here: 18.3.3 Evaluation of Gradients and Derivatives. I have not used this and it is only a guess. If this does not help then we would need to look at post-processing options more closely...
Светлана is offline   Reply With Quote
Old   May 28, 2017, 00:15
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
I know it is straightforward to export node values when writing into ASCII format for example. But I dunno how that would help you interface with Ansys.
That's a method to calculate gradients. That's not a method to export node values into Ansys. It's a solver option, not a post-processing option.
LuckyTran is offline   Reply With Quote
How to calculate the non-dimensional cell size Δx⁺ Mirage Main CFD Forum 3 October 7, 2016 14:16
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
Journal file error magicalmarshmallow FLUENT 3 April 4, 2014 12:25
Node centered and cell centered. Confused. Main CFD Forum 9 August 29, 2003 13:54
calculate cell volume, center...? Paul Main CFD Forum 5 June 21, 2003 12:55
