May 29, 2017, 14:59 |
Density changes in the solid part.
Audrius
Rep Power: 11 |
Hello colleagues,
I would like to perform Fluent validation for natural circulation phenomena with conjugate heat transfer. For the beginning, I created a simple geometry, which consists of two parts: fluid and solid zones. In the bottom part of fluid zone there is water, in the top there is air. The solid part is made from aluminium. After first iteration I noticed, that density of aluminium plate is not the same throughout the solid plate. In the outside of aluminium plate the density is 0 kg/m3. This should not be. When I use the same geometry, the same mesh for single flow, for example, the density of plate is good. I do not understand why what is. I think it's related to the VOF model. Maybe You can explain where I am doing mistake, please? |
May 29, 2017, 22:46 |
Lucky
Rep Power: 65 |
Check the boundary conditions for the aluminum and see if you specified a funny phase. The "density" is the bulk density which is the sum of phase-densities.
In multi-phase problems, it's always a good idea to have a plot of the phase fractions. |
May 30, 2017, 05:45 |
Audrius
Rep Power: 11 |
Here presented properties of aluminium:
Air density: Air volume fraction: Water density: Water volume fraction: And here is density contour in Fluent: Why in the Fluent I see good density, but in CFD-Post with changes? |
June 7, 2021, 05:49 |
cuneyt
Rep Power: 5 |
hi;
did you find the solution ? I have similar problem. I created a solid zone for wall and after initialization, I see that density of solid zone is zero even I entered constant value in materials section. Fluid zone looks ok. |
Current density visualisation (PEM fuel cell add-on module) | pchoopanya | FLUENT | 10 | August 21, 2023 14:33 |
Error Messages: Self intersecting faces, Solid Part is not closed, Floating point. | bigtoasty | STAR-CCM+ | 1 | March 4, 2016 05:05 |
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam | xpqiu | OpenFOAM Community Contributions | 8 | June 17, 2015 02:08 |
How to subtract a part with solid & surface bodies from an enclosure? | woodmark75 | FLUENT | 1 | November 2, 2014 16:57 |
Simulation of a Silo | Attesz | CFX | 20 | October 15, 2010 08:11 |
