How to capture static pressure along any section of a pipe? |
June 2, 2017, 09:44 |
Rep Power: 8 |
I am modelling a 3D 90 degree bend so that I can estimate the friction loss coefficient for the pipe fitting (excluding the major friction caused by straight pipe). In order to do so, I need the static pressure values at the ends of the straight pipe section. Can guide me on how to get the values please? Thanks
June 3, 2017, 12:10 |
Rep Power: 10 |
Can you post a graphic describing your problem? What you call "the ends of the straight pipe section" might mean the inlet and outlet of the geometry, or it could mean the point where the pipe switches from straight to starting to bend.
The good news is that it might be simple to help you, regardless of where the ends of the straight pipe are located. |
June 4, 2017, 00:55 |
#3 | |
Rep Power: 8 |
Here is a picture of what I was trying to convey. |
June 4, 2017, 22:02 |
Lucky
Rep Power: 65 |
You need to clarify what you mean by static pressure at the two points, do you actually mean points or a general region at the axial location?
For points, create a surface monitor (a point monitor). Then there are many ways grab the value of the static pressure there. You can simple select the surface in a plot, select the point, and infer what the pressure is from te ranges. You could also setup monitors or reports. Usually, since you are doing 3D simulations anyway, you like to use more than just point data and get the average static pressure at plane slicing through that axial location. Note however, that it might be better to calculate the total pressure drop rather than the static pressure drop depending on you problem setup. Last edited by LuckyTran; June 5, 2017 at 18:09. |
June 5, 2017, 01:36 |
Kal-El
Rep Power: 9 |
I would monitor the average pressure in those planes.
June 5, 2017, 04:51 |
Rep Power: 8 |
June 5, 2017, 05:08 |
Kal-El
Rep Power: 9 |
Create planes:
https://www.sharcnet.ca/Software/Flu...g/node1120.htm Monitor average pressure on those planes: http://www.afs.enea.it/project/neptu...ug/node815.htm As LuckyTran said, total pressure might be better than static pressure. |
June 5, 2017, 11:45 |
#8 | |
Rep Power: 8 |
June 7, 2017, 03:59 |
#9 | |
Rep Power: 8 |
As for the 'Report Type', which one do I choose? Mass Weighted Average or Area Weighted Average? After I run the calculation, I just have to go to Reports>Surface Integrals to compute the average pressure, right? |
June 7, 2017, 04:10 |
#10 | ||
Kal-El
Rep Power: 9 |
https://www.sharcnet.ca/Software/Flu...g/node1050.htm |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Pressure pulsation in a pipe due to sudden opening | asder | CFX | 3 | March 2, 2008 17:18 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
