Laminar Flow Problem
Old   June 4, 2017, 05:27
Lightbulb Laminar Flow Problem
Ahmad Ijaz
ahmadijaz is on a distinguished road
Hi
I am new to ANSYS Fluent and trying to solve a simple problem using Fluent. I have added the problem description in the attachment section.
After setting up the geometry, meshing and model setup, when i hit the CHECK CASE button before the Run Calculations it pops up with this message. "Apply an axis boundary on the centerline (x-axis)" figure is also attached showing this message.
i have applied the centerline boundary condition then why it is prompting me again for the this condition.
and when i start calculation it stops with an error "Divergence detected in AMG solver: x-momentum"
Last edited by ahmadijaz; June 4, 2017 at 05:29. Reason: adding pictures for details
ahmadijaz is offline   Reply With Quote
Old   June 14, 2017, 08:45
Juan D. Carreño S.
JuanDCS is on a distinguished road
if your using a symmetry condition to the centerline, you need to put it in x axis and before run the simulation in general conditions make a check for the mesh.
JuanDCS is offline   Reply With Quote
Old   June 14, 2017, 09:39
MayTheFlowBeWithYou's Avatar
I have to remain anonymous, I'm sorry.
Location: The Netherlands, Delft University of Technology
MayTheFlowBeWithYou is on a distinguished road
Judging from what you want to do, I don't think you need to actually draw the centerline at all. I would just not draw it, or make the boundary condition for it "interior".
MayTheFlowBeWithYou is offline   Reply With Quote
Old   July 9, 2017, 19:24
Emanuel Camacho
earc96 is on a distinguished road
You just need half of your domain, and then one side will be your axis, that you apply your boundary condition.
earc96 is offline   Reply With Quote
Back flow problem in gas cyclone lakhi FLUENT 0 August 31, 2012 04:27
convergence problem in 3D steady state, laminar flow in a bath vajiheh FLUENT 0 July 10, 2009 12:18
Laminar Periodic flow problem Leigh FLUENT 0 February 14, 2006 06:04
a laminar flow and heat transfer problem majestywzh FLUENT 1 April 16, 2003 03:39
Poiseuille flow problem Rosie FLUENT 1 December 6, 2002 16:52
