June 5, 2017, 15:05 |
convergence in Ansys fluent
dilaw meda
Rep Power: 8 |
hello, i'am new in simulation . after100 itertations, this is the residuals results, what do you think about te convergence and, why always the energy residual is very low compared to the other residuals ?
June 5, 2017, 15:58 |
#2 | |
Lane Carasik
Rep Power: 14 |
Also, please do not post FLUENT questions in the main forum. Please keep these questions to the other forum. |
June 5, 2017, 16:00 |
#3 | |
dilaw meda
Rep Power: 8 |
June 5, 2017, 16:02 |
Lane Carasik
Rep Power: 14 |
You likely want to monitor a few quantities such as velocity, pressure, temperature at a few different points in the domain as well. Those can be used in addition to monitoring residuals for numerical convergence.
June 5, 2017, 16:04 |
Rep Power: 13 |
Energy residual is lower because solution is approached faster than other quantities, perhaps because intial guess is closer to what the simulation calculates as solution. I would run also longer and carefully inspect other flow characteristics like change in mean velocity on a plane etc. to judge convergence. Also inspect whats going on with reversed flow at outlet. This can also go away with further iterations.
June 5, 2017, 16:09 |
#6 | |
dilaw meda
Rep Power: 8 |
June 5, 2017, 16:27 |
Rep Power: 13 |
Let it run further and see what happens to the reversed flow. Then if you think you achieved convergence, try to find out where in your domain reversed flow is present. Reversed flow often occurs if e.g. a vortex extends over your boundary, so that the flow re-enters the domain from outside because of this vortex. If this is the case, extension of Boundary is usually the way to get rid of the problem. I saw that you try to model a cylinder. Is this cylinder a technical device with fixed diameter and length or are you modelling release into atmosphere? When the later, what speaks agains increasing the cylinders diameter..
Good luck |
June 5, 2017, 16:32 |
#8 | |
dilaw meda
Rep Power: 8 |
June 5, 2017, 16:41 |
#9 |
Rep Power: 13 |
I see. But your room has walls, right? Or i'm i missing something here... If your room has walls, then Pressure Outlet does not look correct as BC. You should use wall BC instead and have the top as pressure outlet.
Edit: What i try to say is, model it as a parllelepipede (what a word ) that it is in real life. Use wall BC and Pressure Outlet at top. I think it is more realistic and probably gets also rid of the reversed flow if its occuring on this boundary. |
June 5, 2017, 18:09 |
#10 | |
dilaw meda
Rep Power: 8 |
June 6, 2017, 02:02 |
#11 |
Kal-El
Rep Power: 9 |
I agree. Monitoring the results is the best method for judging the convergence. It gives more information that the residuals.
June 6, 2017, 06:58 |
#12 |
D. N. Venturi
Rep Power: 13 |
This is a very good post about convergence:
Convergence |
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 00:49 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
UDF Defining in ANSYS FLUENT 16.2 in Win 10 | Sadegh.A | Fluent UDF and Scheme Programming | 11 | February 15, 2017 14:45 |
convergence problem in ansys fluent | israr.iitp | Visualization & Post-Processing | 0 | September 5, 2015 06:01 |
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation | Volker P. | ANSYS Meshing & Geometry | 22 | January 17, 2012 17:27 |
