June 8, 2017, 14:00 |
natural convection - density problem
CC
Dear all,
I am trying to simulate the natural convection in an horizontal enclosure: adiabatic vertical walls, a top cold wall and a hot bottom wall. I am simulating the natural convection of water using the Boussinesq model. However, I am not able to get correct pressure values, i.e. for 0.5 m of distance between top and bottom wall I was expecting to get 4180 Pa, but the value obtained was 10 Pa. Moreover, the pressure is higher in the top than in the bottom... Anyone can help me, I was looking through the manuals for an example, but I was not able to find it. Please, anyone have a reference paper which I can use to simulate and validate what I am doing... Best regards, C.C. |
June 8, 2017, 21:39 |
Benchmark solution
Svetlana Tkachenko
https://uiuc-cse.github.io/me498cm-f...n-natural.html
De Vahl Davis, G. (1983), Natural convection of air in a square cavity: A bench mark numerical solution. Int. J. Numer. Meth. Fluids, 3: 249–264. doi:10.1002/fld.1650030305 |
June 9, 2017, 10:17 |
#3 | |
Kushal Puri
Rep Power: 12 |
June 11, 2017, 15:52 |
CC
June 11, 2017, 15:58 |
Kushal Puri
Rep Power: 12 |
June 13, 2017, 09:48 |
CC
Thank you for your reply. I have changed the operating density to the density of water, but still I am obtaining values of pressure that are unexpected to me..
June 13, 2017, 14:24 |
Kushal Puri
Rep Power: 12 |
June 14, 2017, 06:34 |
#8 | |
CC
- top wall, cold wall, T = 273.15 K - bottom wall, hot wall, T = 293.15 K - left and right walls are adiabatic walls Natural convection in a enclosure of 1m x 0.5m.... |
June 14, 2017, 10:47 |
Kushal Puri
Rep Power: 12 |
June 16, 2017, 11:52 |
CC
June 20, 2017, 05:05 |
#11 |
ybyo
I'm not expert but have few questions. Why people using Boussinesq for a very well known temperaute range for air properties especially.
You set your operating temp to 20 C but your range is between 0-90 degrees right? Try to calculate Boussinesq model density output, by using thermal expension, operating temperature density, instant temperature. And we know air density values vs temperature change. This is a narrow band. So compare your findings with experimental density values. If you choose an op temperature far away from the average in your temperature range (20 C for 0-90 C band) you will see an error in Boussinesq model density vs experimental which is groving non-lineerly while it is closing to top temperature. I believe this could effect results dramatically. If you are using constant thermal expension rate for operating temperature, this would even make worse. I was going to open a thread to ask my method but after i saw a natural convection problem in the first page (usual) i instead decided to post here. What do i do is, entering tabular data for density, viscosity, thermal conduction values for air vs temperature changes. Of course this works in a narrow band (-50 ~ 100 C usually) but Boussinesq's itself doesnt work for wider! I'm making a simulation right nnow and converging faster after i did this. And the most important is it is stable. So please consider and evaluate my method people. Cheers |
Flow is not converging in natural convection problem of boussinesq model for air | rahulsharma | FLUENT | 4 | December 2, 2020 22:07 |
convergence problem in natural convection | paps | ANSYS | 0 | December 1, 2013 06:04 |
Natural Convection Problem | Eduardo | FLUENT | 0 | October 21, 2006 15:04 |
Operating Pressure (Natural Convection problem) | Andrew Tress | Main CFD Forum | 1 | July 3, 2006 17:00 |
transient simulation: natural convection problem? | Basics | CFX | 3 | September 25, 2002 10:42 |
