June 19, 2017, 14:19 |
DNS and LES in FLUENT
Shashank
Rep Power: 11 |
While running LES in FLUENT as we run a steady state K-epsilon model for getting a converged solution and once the flow is converged we use LES model to get transient results. Can we follow a similar approach for performing DNS in FLUENT, just by selecting the laminar model after a steady state k-epsilon gets converged?
June 20, 2017, 06:02 |
For a DNS you need a very fine mesh and a very fine time step. Selecting "laminar" alone is not enough for DNS. I don't see any advantage in having a steady state solution as initial guess for a transient DNS. What is the idea behind this?
June 20, 2017, 07:37 |
Shashank
Rep Power: 11 |
The idea is to get fully resolved turbulent length and time scales for a flow past a sphere at high Re. I have already run LES for a Re of up to 5000. I am able to reproduce results for pressure coefficient vs theta, drag coefficients, lift coefficients, energy spectra, strouhal number to mention a few. But the problem is I have been told several times by my colleagues that since in LES we model certain terms we cannot say that we have fully resolved the flow just by using fundamental NSE, to have a fully resolved flow it is essential to go for a DNS. The purpose is to get more insights in terms of physics for the above mentioned case. Kindly suggest whether the above purpose could also be fulfilled by LES or should I necessarily go for DNS?
June 20, 2017, 08:01 |
Yes, with LES you have a model for the kinetic energy of the eddies that are smaller than your grid size, the Subgrid Scale Model.
If you want to solve ALL the turbulent effects from NS, you need a very fine mesh that can resolve down to the Kolmogorov Microscales, where kinetic energy is dissipated into heat. https://en.wikipedia.org/wiki/Kolmogorov_microscales So what you can do is try to calculate the needed grid size and time step size for this DNS approach. It usually is absolutly not doable without a supercomputer. On the other hand, if you have already good agreement with experimental data from the LES approach, doing a DNS seems academical, doesn't it.. |
dns, les, transient |
Time required for RANS vs. LES vs. DNS | Wingman | Main CFD Forum | 5 | September 25, 2021 08:28 |
Best way to handle hanging nodes in Fluent for LES? | flotus1 | FLUENT | 4 | December 16, 2013 03:32 |
doubt about DNS and LES of combustion | chinthakindi | Main CFD Forum | 5 | August 17, 2013 11:56 |
DNS and LES resolution | Larsen | Main CFD Forum | 0 | November 25, 2010 18:10 |
Laminar solver? LES? or DNS? | Ray | Main CFD Forum | 5 | March 19, 2003 10:19 |
