Fluent Drag Estimations are Twice Experimental Data
Like Tree1Likes
  • 1 Post By diamondx
Old   June 19, 2017, 16:56
Default Fluent Drag Estimations are Twice Experimental Data
Thusitha
Thusitha is on a distinguished road
I'm having difficulty in matching experimental aerodynamic data (drag) for naca0006.
The fluent simulations results seems to be roughly twice the experimental data for up to 10deg.
The speed, RE, Mach, Density, Pressure, Viscosity are: 42.023 m/s, 0.124, 1.225 kg/m3, 101325 pa, 1.716e-5 kg/sm.
Turbulence intensity, length scale, modified turbulent viscosity are: 0.00069%, 0.0078, 2.77e-6.
Pressure based model/spalart allmaras viscous model. The y+ is below 1 and the plate length is 1m.
Can anyone point out what's wrong?
Sent from my iPhone using CFD Online Forum mobile app
Thusitha is offline   Reply With Quote
Old   June 19, 2017, 22:53
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
the drag coefficient is computed using the reference values. Make sure those are correct. I think you can set the compute from "inlet"
Thusitha likes this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 20, 2017, 03:10
Thusitha
Thank you for your reply.
Does it apply for Lift as well? Because, Lift is a good match; it's the drag that doesn't disagree.
I tried various values for boundary conditions (turbulent intensity, length scale, modified turbulent viscosity etc.), but the result is the same.
I have also tried with two grids: one coarse and one fine, still the result is the same.
BR
Thusitha
Old   June 20, 2017, 03:16
Thusitha
PS - The reference values are computed from Inlet as well (see my previous comment)
FLUENT: how to record drag force at every time step? qiulan FLUENT 4 March 20, 2017 21:22
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
Fluent crash on writing data file after thousand iterations Chuck87 FLUENT 0 September 2, 2015 16:17
Induced drag, pressure drag, viscous drag. aleix.de.toro FLUENT 2 August 24, 2015 18:00
Fluent validation test for calculate the drag of a car ostervi FLUENT 0 June 12, 2009 12:59
