May 15, 2012, 15:13 |
multi-fluid VOF model
Fer Villa
Rep Power: 13 |
I want simulating the slug flow, this flow is composed of a Taylor bubble flowing in water with small bubbles dispersed. So i have three phases: first phase is liquid (water), secondary phase is the air in the Taylor bubble(for which i need reconstructing of the interface) and the last secondary phase is the air in the small bubble (dispersed in the liquid)
I'm using the Eulerian model with multi-fluid VOF explicit (Explict due to have available the geo-reconstruction method for interface) Someone know how introduce the dispersed phase in the explicit Eulerian model using multi-fluid VOF available in the Fleunt 14 (I think that is available in Fluent 13 too) Thank you!! Last edited by fevi84; May 15, 2012 at 15:29. |
September 6, 2013, 16:28 |
Shawn Fotovati
Rep Power: 16 |
Suppose your liquid phase is the secondary phase, go to Phases, select the secondary phase, and edit. on the properties, you can define the disperse properties.
June 23, 2017, 02:43 |
#3 | |
Masoud Ravan
Rep Power: 9 |
I have the same problem Did anyone know how to use MultiFluid VOF in the Eulerian model?? Thanks in Advance |
Wich model in gas-gas (VOF, MM or EM) | louiza | FLUENT | 0 | May 25, 2010 05:59 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
urgent query regarding vof model plz rply | Garima Chaudhary | FLUENT | 0 | July 13, 2007 02:20 |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 07:15 |
VOF Model, Please Guide. | Colin | FLUENT | 4 | May 26, 2003 14:05 |
