June 26, 2017, 01:44 |
Boundary condition
Abhishek Patil
Rep Power: 9 |
In my model I have two inlet. The fluid from second inlet is driven by the pressure drop created using the flow of fluid from first inlet. I want to check the pressure and mass flow at outlet.
I'm trying to simulate this case using velocity inlet and outflow but I'm not getting correct results. Can anyone suggest me correct boundary conditions? Specifically at second inlet because I know only pressure at this inlet. Sent from my Lenovo K50a40 using CFD Online Forum mobile app |
June 26, 2017, 08:00 |
Rep Power: 12 |
So basically you want to study how big is the mass flow from the second inlet? Like you wrote, the suction created by the first outlet will define the second mass flow, so if your first mass flow is already settled, you could try to change the geometry of the second inlet. You might have incorrect dimensions for the second inlet if the mass flow is not correct.
June 26, 2017, 10:02 |
Abhishek Patil
Rep Power: 9 |
I know first inlet mass flow, second inlet pressure and at outlet I don't have any value or parameter. I want to find out flow parameters at outlet and mass flow at second inlet.
Both inlets have circular cross section. Not any complex shape.. Sent from my Lenovo K50a40 using CFD Online Forum mobile app |
June 27, 2017, 03:07 |
Rep Power: 12 |
If it's raw numbers you're looking for, why can't you just use report command to get the values?
report/fluxes/mass-flow inlet1 inlet2 outlet () Code:
report/surface-integrals/vertex-avg outlet () velocity-magnitude () |
June 27, 2017, 23:50 |
Abhishek Patil
Rep Power: 9 |
Will mass flow from second inlet change, if I'm giving specific boundary condition?
June 28, 2017, 01:35 |
Rep Power: 12 |
If you define for instance that the mass flow of the second inlet is 1 kg/s, then this value is what you get from Fluent. It is probably a nice idea just toy around with the different boundary conditions in order to get a conception of the playground.
If you already know what the mass flows of the first and the second inlet are, I would suggest that you would define them exactly with mass flow inlet boundary condition. |
June 28, 2017, 01:49 |
Abhishek Patil
Rep Power: 9 |
No I don't know exact value at second inlet. I want to find out from CFD.
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Accessing multiple boundary patches from a custom boundary condition file | ripudaman | OpenFOAM Programming & Development | 0 | October 22, 2014 18:34 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
