June 28, 2017, 19:05 |
lift saving
antony morgan
Rep Power: 8 |
hello every body. in monitor panel in fluent software i want to save lift coefficient data in every 'n' time steps(i.g every 20 time steps) how can i do that?
regards |
June 29, 2017, 14:55 |
Paul
Rep Power: 9 |
Exactly how you do it depends on what version of Fluent you're running on. For v18, right click "Report Definitions" and create a new "Expression" for the C_L. For v17 it may be slightly different because they changed the process of how monitors are made.
June 29, 2017, 16:17 |
antony morgan
Rep Power: 8 |
tnx for your answer. i,m using ansys15.07 but i can't see any option there. here is the lift writing panel
June 29, 2017, 16:42 |
Paul
Rep Power: 9 |
Well then your best bet would be to export the lift data every 20 time steps, bring the "Lift.out" file (or whatever you named it) into excel, and make the C_L calculation in excel.
If possible, I would also recommend upgrading to a newer version of Fluent. It has many more options that make setting up simulations less painful. |
How to calculate lift, drag and lift distribution in Star CCM+? | israelcasillas94 | STAR-CCM+ | 4 | November 6, 2020 08:35 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Saffman Lift Force: confused | CFD_MAN | FLUENT | 5 | September 9, 2010 04:51 |
Thin foil analsis (sail) - Lift Coeff Problem | Kelvin | CFX | 3 | December 22, 2008 16:22 |
Lift force or coefficient of lift | Rola | FLUENT | 1 | November 12, 2006 13:29 |
