How to save model parameters after importing new mesh?
Old   July 5, 2017, 06:12
Default How to save model parameters after importing new mesh?
h0rst is on a distinguished road
Hello everybody,
I am calculating the electromagnetic field with ANSYS Classic and export it to ANSYS Fluent. I often need to change the mesh for optimization issues and I have to do it in the ANSYS Classic model.
After exporting the mesh again to Fluent, I need to adjust all parameters again (model, zones, monitors, cell zone conditions, boundary conditions etc.).
Is it possible that Fluent saves these parameters when I import a new mesh?
Best regards
h0rst
h0rst is offline   Reply With Quote
Old   July 9, 2017, 20:20
Emanuel Camacho
earc96 is on a distinguished road
If I got it right, are you loading a new case?
earc96 is offline   Reply With Quote
Old   July 17, 2017, 02:48
The case is the same, I just import a new geometry (mesh) from Ansys mechanical APDL.
Old   September 27, 2017, 12:55
Emanuel Camacho
Since you have your case saved, what you can do is replace your mesh, by selecting Read > Mesh, and then replace it.
Old   September 28, 2017, 19:19
Lucky
You can also save a settings file using the text interface. File=>write-settings and then read this settings file into your new case. But this method can fail for example when you re-name a zone as it doesn't know what settings go to what zone.
Your best bet is to just write a journal file to set all the settings.
[ICEM] Problem with Hexa-Dominant Mesh in a 3D Voxelized Model bidi ANSYS Meshing & Geometry 0 December 26, 2016 05:00
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
Problem importing watertight model into CFX djk1301 ANSYS 3 February 1, 2011 23:04
