Laminar Anisotropic Flow - Acetic Acid in Water Is Not Diffusing
Acetic acid in water is not diffusing for an anisotropic laminar flow simulation. The model is a 200 m x 200 m domain. The viscous models are laminar and species transport. The fluid materials are acetic acid and water. For the anisotropic UDS diffusion the matrix components for XX and YY are 3 and 1, respectively. The diffusivity is 31.5 kg/m-s. The boundary condition type for each wall is outflow. The user-defined function for the initialization of the flow follows.
/************************************************** ********************* UDF for initializing contaminant distribution ************************************************** **********************/ #include "udf.h" DEFINE_INIT(init_distrib_anisotropic,d) { cell_t c; Thread *t; int i; real xc[ND_ND]; /* loop over all cell threads in the domain */ thread_loop_c(t,d) { /* loop over all cells */ begin_c_loop_all(c,t) { C_CENTROID(xc,c,t); C_YI(c,t,0) = (1.0/4.0/3.141593/120.0/sqrt(0.09)/sqrt(0.03))*exp(-1.0*pow(xc[0] - 99.75,2.0)/4.0/0.09/120.0)*exp(-1.0*pow(xc[1] - 99.75,2.0)/4.0/0.03/120.0); } end_c_loop_all(c,t) } } After running the simulation for ~ 980 seconds the diffusion is virtually unchanged. Why is the acetic acid not diffusing in the water? What am I setting up incorrectly? Thanks, Lisa |
