boundary condition with pressure AND mass flow rate |
July 19, 2017, 13:45 |
I am simulating the flow in a combustion chamber of an aircraft engine. The pressure and the mass flow rate are well defined in the experimental data. It is a compressible flow and the outlet is a pressure boundary condition at 1 atm. For the numerical part, I want to define a boundary condition (BC) in fluent with a given mass flow rate and a given pressure. In fluent, the "mass-flow-inlet" BC enables us to have a given mass flow rate but how can I define the pressure at the inlet? There is an option to input an initial gauge pressure but I found in the help document this sentence in the "Mass flow inlet boundary conditions section": "The Supersonic/Initial Gauge Pressure is ignored by ANSYS Fluent whenever the flow is subsonic." Hence I want to know is there a way to define the pressure at the inlet? If not, how can I treat the problem? |
July 20, 2017, 08:39 |
Lucky
Rep Power: 65 |
You can't specify both pressure and mass flow at a boundary, that would over-constrain the problem.
April 14, 2022, 08:03 |
Ross Grant
Rep Power: 4 |
Have you found a way to solve this issue? I am experiencing a similar problem regarding the filling of a hydrogen tank. Regards, Ross |
April 14, 2022, 12:32 |
Lucky
Rep Power: 65 |
You can't specify both mass flow rate and pressure, it makes no physical sense, unless the flow is supersonic. If the flow is supersonic, then the option is readily available.
If your flow is not supersonic and you're trying to constrain both mass flow and pressure, then you need to rethink your approach because you're doing it wrong. |
boundary condition, fluent, mass flow inlet, pressure and velocity |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
