bulk Temperature
Old   July 25, 2017, 01:31
Default bulk Temperature
saha2122 is on a distinguished road
Send a message via Yahoo to saha2122
Hi everybody.
I have a Conjugate 2D Fluent model. The geometry containing turbine disk. After solving I extract heat flux and wall temperature on some selected walls.I want to find a good bulk temperature that (Twall - Tbulk) could explain the flux sign and trend!
when Tbulk>Twall, I expect that related wall gain energy and fluid vice-versa!
However I tried many definition, unfortunately I couldnt find a good bulk Temperature that physically be justifiable.
Is there anybody that could help me??
saha2122 is offline   Reply With Quote
Old   July 25, 2017, 06:33
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
Is your mesh separated in cellzones? If there is a separate cellzone next to wall, you could use the average temperature of that zone.
What software did you use to make your mesh?
KaLium is offline   Reply With Quote
bulk temperature, conjugate model, fluent, htc
What is the accurate and best way to calculate bulk or mean temperature? Shomaz ul Haq FLUENT 9 December 23, 2018 03:48
Bulk temperature expression gives value below inlet temperature for half the pipe Shomaz ul Haq CFX 3 June 21, 2017 03:40
Bulk Temperature Zohud FLUENT 3 February 23, 2017 13:14
Bulk mean fluid temperature in internal flow mssound FLUENT 0 May 13, 2010 15:56
Bulk temperature emad FLUENT 0 February 1, 2008 07:45
