define wall functions (UDF) in Fluent 6.3
Like Tree1Likes
  • 1 Post By sbaffini
Old   March 11, 2008, 12:32
Default define wall functions (UDF) in Fluent 6.3
Alex
Hello all,
I have been trying the example of DEFINE_WALL_FUNCTIONS in the Fluent 6.3 UDF manual (paragraph 2.3.23), but it doesn't seem to compile in Fluent. What I get in the log report is the following:
udf_names.c:8: error: 'user_log_law' undeclared here (not in a function)
udf_names.c:8: error: 'UDF_TYPE_WALL_FUNCTIONS' undeclared here (not in a function)
Could it be the case that I need to give some additional details in the UDF script?
Alex
Old   March 24, 2008, 03:39
Default Re: define wall functions (UDF) in Fluent 6.3
Dave S
Before compiling the UDF in Fluent you need to start Fluent in a C++ DOS window.
Old   March 24, 2008, 07:15
Alex
Thanks for your reply,
I figured out what was the problem. I was using the udf.h file from the previous version (6.2) so I updated the new one.
Alex.
Old   September 20, 2014, 12:37
Default meaning of DUPLUS AND D2PLUS
Qureshi M Z I
m zahid is on a distinguished road
hi,
anybody know the meaning of DUPLUS and D2PLUS. these terms are used in UDF wall function example and also why the equation of both terms are different,
thanks
zahid
m zahid is offline   Reply With Quote
Old   August 2, 2017, 00:01
Yousef
yousefaz is on a distinguished road
When defining a wall function UDF in Fluent, the user is required to specify equations for the dimensionless velocities U* and its derivatives with respect to dimensionless distance away from the wall (y* or y+).
Hence, DUPLUS is the first derivative: dU*/dy+ and D2UPLUS is the second derivative d2U*/d(y+)2.
yousefaz is offline   Reply With Quote
Old   August 2, 2017, 02:24
Qureshi M Z I
thanks yousefaz
Old   August 3, 2017, 07:45
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
That's basically true.
You might want to give a look at this for more details:
https://www.politesi.polimi.it/bitst...Monticelli.pdf
m zahid likes this.
sbaffini is offline   Reply With Quote
LES with wall functions, wall boundary, Re 10000 subba CFX 4 July 10, 2007 05:04
impossible for fluent 6 to handle wall functions!? mike FLUENT 0 November 15, 2006 19:18
damping functions(wall functions) Pr Main CFD Forum 0 March 22, 2004 02:17
abt near wall turbulence wall functions amv Main CFD Forum 0 May 12, 2003 03:38
Can I define grids motion as a time functions Darcy CFX 4 March 29, 2001 21:14
