[Sponsors] | |||||
Khalid Baker
Rep Power: 18 ![]() |
Hello I attempted to plot stream function in CFD-Post but I do not find it? may somebody tell me where i can find it please?
regards Khalid Baker |
Abhinand
Rep Power: 11 ![]() |
I guess you must enable it from data file quantities while you calculate the solution in setup tab File-> data file quantities select all the necessary quantities you want to write and maybe after then you will get the stream function in the CFD post Cheers |
#3 | |
Khalid Baker
Hello I cannot find file quantities in file menu in CFD-Post where I can find it exactly?
Abhinand
It will be in the setup menu. While calculating the solution you must write the stream functions also to view in CFD post
Rep Power: 17 ![]() |
Abhinand
while doing your simulation in set up tab. Before your click on calculate for iterating the solution to get converged, you must go to File -> Data file quantities -> Stream function.
Only after you write the values of stream function you can access in CFD post If you are having doubts, have a look at this https://www.sharcnet.ca/Software/Ans...e_options.html cheers |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| CFD post: Find area with variable above a certan value | evcelica | CFX | 4 | March 7, 2014 21:04 |
| [blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
| [blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
| latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 05:37 |
| Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
