[Sponsors] | |||||
Mohamed Mousa
Rep Power: 10 ![]() |
Dear all,
I ran a multi-phase (VOF model) case and I set solution animations. After calculations I need to add another contours to be animated. Is it possible to set new animation after calculation ? Another problem, when I attempted to use the CFD post instead, there is no option for "volume fraction". Only density, wall heat flux and radiative heat flux are the properties available for each phase to be displayed. Thanks in advance |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
| Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 11:54 |
| What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 12:55 |
| Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 17:41 |
| fluent journal files - speedup your postprocessing | warlock | FLUENT | 0 | March 9, 2006 00:36 |
