[Sponsors] | |||||
Rep Power: 10 ![]() |
Please I am having issues loading case and data files for multiple simulations I've run. I have the .dat file available, but when I try importing case and data into fluent, it only imports the case. Furthermore, it doesn't allow me to just import a .dat file through the Import Data option. Does anyone know why this occurs?
Thanks, JJ |
Lucky
Rep Power: 68 ![]() ![]() ![]() |
What is this about importing? Are you in WB or Fluent? In Fluent you need to read the case and data file, not import.
In the GUI ribbon go to file=> read In the TUI type something like rc blah.cas rd blah.dat You can also omit the .cas and .dat, Fluent knows to look for those extensions. rcd blah Will look for blah.cas and a blah.dat |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
| [swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 16:14 |
| [OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
| [swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 14:59 |
| friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
