[Sponsors] | |||||
abdulhamit
Rep Power: 12 ![]() |
I am doing the analysis of the melting of PCM in heat exchanger. First I created 511000 mesh using ANSYS 17.2 student. 0.006 time step, 10 max iteration/time step, using 3000 seconds solved in 40 days. I think, result is partially false because The PCM consists of tetra and hex. Due to the hexa mesh, the melt becomes regular. The residual x,y,z, contiunity and energy are in a straight line. Whenever I increase time step, the residual become like this; ![]() I started an analysis again. This time I am using ANSYS 17.0 crack. I made 1000 000 mesh. Now the melting is getting better. The most important problem is this. The processor is using 20% and the RAM is 3.7gb. my system i7 2630qm 2.00ghz 4 cores 8 threads, 8gb ram. Why not use all of the processor? simulation 1; 500 000 mesh 19 iteration/minute, It solves 165 seconds in 24 hours. it finished simulation 2; 1000 000 mesh 4 iteration/minute, It solves 35 seconds in 24 hours. it is continuing. now 75 second I need about 40-50 minute simulation. relaxtion factor. pressure 0.5 momentum 0.5 energy 0.75 courant number: 1=(U*t)/x velocity x y z>>>>converge passive contiunity and energy>>> 0.001 0.00001>>>>converge active Please help me. What should I do? Last edited by kaazto28; August 13, 2017 at 14:56. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
| Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 10:23 |
| [snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
| [mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
| SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
