Interaface wall boundary condition in conjugate heat transfer
Old   August 13, 2017, 02:30
Default Interaface wall boundary condition in conjugate heat transfer
Njit
Njit is on a distinguished road
Hello
I am solving a conjugate heat transfer problem. I have created a 2D geometry where the upper part is a solid and the lower part is a fluid. Constant heat flux is applied on the outermost wall.
What boundary condition should be specified in the interface wall between solid and fluid part such that the heat transferred though the solid part is transferred same to the fluid part. Or is there any method of coupling so that same heat is transferred through the fluid part.
Thank you in Advance!
Njit is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 21:11
