post processing phase boundary
Old   August 13, 2017, 22:29
Default post processing phase boundary
aleph96 is on a distinguished road
I'm working on the surface treatment of some fibers and here's a contour of one of the results in attachments. The small circles are cross sections of the fibers to be sized, the deep blue fluid is the sizing agent, the transparent fluid is the air. The sizing agent is penetrating into this bundle of fibers due to outer pressure and surface tension.
What I'm trying to do is to create a chart that plot the penetration depth of the sizing agent against time. I would like to calculate the penetration depth by the difference between the outer radius of this bundle of fibers and the average of the distance of the phase boundary from the center.
Is it possible to do it in CFD-Post?
(I'm not sure it's relevant...but this is a transient problem using laminar flow model and VOF model. )
Thanks a lot!
aleph96 is offline   Reply With Quote
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
