August 17, 2017, 06:30 |
Surface Monitor for Two Phase Flow?
Rep Power: 11 |
Dear all,
I am pretty confused, If I select domain of phase 2 (liquid) - I can display VOF as 1 for full liquid. and 0 means no liquid at all and Phase 1 VOF (1) will be display full air? right but different colour. So I got a plane cut through the domain, I am interested to see if the velocity field has reached steady-state (from initial transient stage). So in the SURFACE MONITORS it says "Area-weighted Average" for example and DOMAIN OF MIXTURE PHASE-1 PHASE-2. So which means in the plane, some part of the cells will be fully air and some part fully liquid and some interface (mixture)? So if I get the "Area-weighted Avg" for velocity-magnitude and I plot a against time-step, and I selected mixture. Which means It will calculate all cell faces with MIXTURE (VOF 0 - 1) and compute the avg velocity-magnitude ? That is to say that the Velocity field of air is not computed otherwise the value will be greatly differ? Am I right? Thanks Kind regards, Jee Loong |
August 17, 2017, 15:44 |
#2 | |
Lucky
Rep Power: 65 |
Furthermore, there is no velocity field belonging to only air and another velocity field belong to the liquid (you do get such fields in a full Eulerian multiphase model) but the VOF approach does not do this. There is only one velocity field for the MIXTURE. |
[General] Mass Flow Using Surface Flow Filter Incorrect | t8fanning | ParaView | 1 | March 13, 2017 05:56 |
Two phase flow problem. | andyraq | Fluent Multiphase | 4 | August 21, 2016 21:57 |
Multi phase flow VS Free surface flow | Kiffer | Main CFD Forum | 0 | November 17, 2012 00:17 |
2 phase flow, free surface instability issues | Doginal | CFX | 29 | September 19, 2012 18:37 |
LES on two phase flow | Li Yang | Main CFD Forum | 0 | May 12, 2004 08:10 |
