Stream function contours on a 2d plane of a 3d geometry assuming Z component as zero
Old   August 21, 2017, 04:36
Default Stream function contours on a 2d plane of a 3d geometry assuming Z component as zero
chirag khalde
chirag is on a distinguished road
Dear All,
I am trying to compare 2d case (S-shaped ) and a 3d case (S- shaped with defined thickness).
2D:
Stream function is available in 2D so I could get that!
3D:
As stream function are 2d, I am trying to define a stream function on the cut plane where Z=0.5. I want to assume Z component as zero.
I donot wish to use stream traces as they are in nature 3D.
Please help!
chirag is offline   Reply With Quote
fluent, stream functions
[swak4Foam] foam-extend-3.2 groovyBC example wont execute JFM OpenFOAM Community Contributions 0 June 17, 2016 09:32
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
stream contours in 3D geometry satya FLUENT 5 September 28, 2003 05:06
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
