fluent error gui-domain-label: no domain selected Error Object: 1038410352 |
Farhad
Rep Power: 8 ![]() |
Hi all,
I'm investigation natural convection on a assembly. I've started a 10s flow-time simulation (time step sizes 0.0015s ~6700 time steps). The issue regarding the subject of this thread appeared after 6000 time steps (before that the calculation run 3 days without any issues). Plesae also find attached the error message: "fluent error gui-domain-label: no domain selected Error Object: 1038410352" Just click "Ok" doesn't work, however after closing that error-window the calculation goes on. But I need to close it after every time step as it appeares regularly... Does anyone know this issue. Do you have any idea how to solve this problem? Thanks in advance for your support Best regards Fari |
Farhad
I still do not know why that error window appeared, however I've solved the problem by downloading a free ware for automated mouse clicks.
It has closed the error message repeatedly, till the calculation was done. ![]() |
#3 | |
Saheed
Rep Power: 0 ![]() |
I hope it helps. |
Daniel
Rep Power: 9 ![]() |
This can happen when the report definitions are not valid. Please check your report file definitions.
Sandeep Gosavi
I am facing the same issue here. However, I don't want to uncheck the data sampling for time statistics. I checked, rechecked my report definitions as well. Anyone figured this out, what is the reason of this error.
Vivek MJ
Rep Power: 4 ![]() |
Kira
Rep Power: 7 ![]() |
Creative workaround! Gave me a chuckle, how you just went 'Take that, machine. I'm in control here, give me my simulation results!'
Display Modes | |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
[ICEM] domain interface in ICEM for fluent | hsn | ANSYS Meshing & Geometry | 24 | November 27, 2012 16:43 |
How to change domain extents in fluent | kbs | FLUENT | 4 | April 26, 2008 16:32 |
