bin_particles_in_cells
Old   May 21, 2014, 02:20
Default bin_particles_in_cells
massoud
massoudepsilon is on a distinguished road
Hi everybody,
is there anyone who knows that what the macro (bin_particles_in_cells) exactly does?
Thank you so much,
massoudepsilon is offline   Reply With Quote
Old   April 10, 2015, 13:15
B_Kia
HyperNova is on a distinguished road
hi
From 3 years ago u are still stuck in that ?!
HyperNova is offline   Reply With Quote
Old   April 10, 2015, 19:40
`e`
`e` is on a distinguished road
Wow, you're not wrong, he's asked the same question on 11th of November 2011.
It appears this macro loops over all the particles in a domain on a cell-by-cell basis according to this page.
`e` is offline   Reply With Quote
Old   April 10, 2015, 19:41
`e`
If this macro has been removed (or altered) between versions of Fluent, you may require some code adjustments. What are you trying to achieve overall?
Old   April 11, 2015, 00:58
B_Kia
hi 'e'
i wrote my code and i used
bin_particles_in_cells(d); /* particles are bined in each cell of the fluid domain */
but this works ok in fluent 6.3.26 but in v15.0 no, in v15.0 it changed , in cl_dpm.h it wrote :
FLUENT_EXPORT void bin_particles_in_cells(Domain *domain, cxboolean init_cells);
there is another argument and i dont know what to write there .
i am working with dpm and i want to add source terms to k and epsilon.
any idea ?
thanks for your reply
Old   April 11, 2015, 01:00
B_Kia
i found him in another thread in 2011 as you mentioned
Old   April 11, 2015, 02:37
massoud
[QUOTE=HyperNova;541073]hi
4 years ago I needed this macro for a project. but I solved the problem with another method.
last year for another project I needed it again. but no one could answer my question. but I solved the problem on my own.
it seems that you feel high self confidence and make fun on the others. I am waiting to see how long it takes you to solve the problem.
good luck
Old   April 11, 2015, 02:53
`e`
If you want to add source terms to k and e of the turbulence model of the continuous phase then use the DEFINE_SOURCE macro.
As for looping through all particles, try this code (source):
Injection *I, *Ilist = Get_dpm_injections();
Particle *p;
loop(I, Ilist) // loop through all injections
    loop(p, I->p) // loop through all particles
        // all particles execute this code
Old   April 11, 2015, 05:07
B_Kia
masoud come on , i need it quick
i used
but it just works in fluent 6.3.26 , in v15.0 it doeant work and it says it needs another argument! id cl_dpm it wrote
i dont know what is cxboolean init_cells and what should i put there , masoud please help!
Old   April 11, 2015, 05:08
B_Kia
this is my UDF
DEFINE_SOURCE(k_new_model_all_terms,c,t,dS,eqn) /* source term for the k equation */
Domain *d=Get_Domain(1); /* domain used in the particle loop. this should be the fluid domain , change index if necessary*/
Particle *p; /* particle index to be used in particle loop */
double umean[3], vmean[3], mass_mean, diamp, V_relative; /* declaration of variables */
double Skp, Sep, Rep, aaa, Mu, rho, TKEDR, TKE, v_mean[3];
int i; /* index used in for loops */
real g = 9.81; /* gravity constant */
real ce3 = 1.0; /* proportionality constant */
real x[ND_ND]; /* this will hold the position vector */
real depth = 0.42;
real injection_height = 0.01;
real Temp = 25.0;
real Pressure_REF = 101325.0;
real MolarWeight = 28.97; /* air */
real ST = 0.072;
real Ck1 = 6.0;
real Ck2 = 0.75;
real Ce1 = 4.0;
real Ce2 = 0.6;
real gas_density, P, Eo, Cd, Cd_sphere, Re, Cf, dpm_frac;
real a11, a22, a33, a12, a13, a21, a23, a31, a32, sen, Production_K;
Alloc_Storage_Vars(d, SV_DPM_PARTICLE_BIN, SV_NULL); /* memory is allocated for the particles which are to be bined in each cell */
begin_particle_cell_loop(p, c, t) /* loops over all particle p which are contained in each cell c */
Old   April 11, 2015, 07:59
B_Kia
Particle *p;
i put my code here , upper of this message, would you mind taking a look of that, that sentence in red color id making problem, i don't know why particles deleted from domain automaticly ,
with bin_particles_in_cells(d); Fluent says another argument is needed, in another thread (http://www.cfd-online.com/Forums/flu...s-command.html) LICH tried to put 0 1 true false as another argument but i did not work for him and me either, if you have any idea i will be thankful if you share it ,
Old   August 28, 2017, 03:36
Default UDF for looping on all particles in each cell.
  #12
massoud
Since Fluent 12, the implementation of bin_particles_in_cells(domain, count) has changed and you need additional macro (unthread_particles_to_all_inj(domain, check)). Please be aware that this additional macro had only one argument at least until Fluent version 14. Since Fluent 17 it needs 2 arguments (domain and check (which is a boolean variable)).
Here is a simple UDF for looping on all particles in each cell.
DEFINE_ADJUST(Looping, domain)
cxboolean count;
cxboolean check;
Thread *t;
cell_t c;
Particle *p;
Alloc_Storage_Vars(domain, SV_DPM_PARTICLE_BIN, SV_NULL);
bin_particles_in_cells(domain, count);
thread_loop_c (t,domain)
begin_c_loop(c, t)
begin_particle_cell_loop(p,c,t)
/* you can do your calculation on particles in one cell here*/
end_particle_cell_loop(p, c, t)
end_c_loop(c, t)
unthread_particles_to_all_inj(domain, check);
Free_Storage_Vars(domain, SV_DPM_PARTICLE_BIN, SV_NULL); /* release allocated memory*/
bin_particles_in_cells, dpm, fluent, udf
