Turbulence Model in axisymmetric nozzle simulation |
May 21, 2013, 03:03 |
Rep Power: 13 |
Hi
I am simulating an axisymmetric nozzle. I have an issue with which turbulence model to use. Currently I am using standard K-epsilon and i am not getting any shock wave inside the nozzle. When I switch to SST K omega i get shock wave in the flow. I would like to ask which is the recommended turbulence model for these type of flow |
May 21, 2013, 06:27 |
OJ
Rep Power: 19 |
By intuition, std k-eps model is diffusive and hence may smear out the sharp gradients responsible for shocks. Have you tried realizable model? It is deemed to be good in modelling jets.
OJ |
May 22, 2013, 12:50 |
Rep Power: 13 |
Yes, Just tried realizable.. it also shows a shock wave
September 4, 2017, 13:11 |
Jeff Yam
Rep Power: 8 |
Hi, could i ask you what do you mean by diffusive?
September 4, 2017, 17:57 |
Arjun Kalkur
Rep Power: 8 |
K-epsilon does not behave well in large pressure gradient, one like shocks, I'd suggest to stick with SST. By diffusive he means the behavior of the solver, like for eg:- Picks the information from the succeeding nodes and moves forward
September 5, 2017, 00:35 |
Jeff Yam
Rep Power: 8 |
I see that the SST k-omega model is more suitable for compressible flow into a nozzle for its good behaviour in adverse pressure gradients (shock) and separating flow. Thank you for your help!
Display Modes | |
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 21:21 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 04:27 |
