How to calculate Nusselt Number in Fluent
Like Tree2Likes
  • 1 Post By CeesH
  • 1 Post By vidyadhar
Old   September 4, 2017, 13:05
Default How to calculate Nusselt Number in Fluent
Ramakant Gadhewal
Location: Chemical Engineering,National Institute of Technology,Warangal (T.S.),India
ramakant is on a distinguished road
Dear All
I need your help how to solve the Nuseelt number formula to plot GRAPH
between length vs Nusselt number.I do not how to calculate DTm/DX, Ts, and Tm.
Thank you
Regards
Ramakant
ramakant is offline   Reply With Quote
Old   September 5, 2017, 04:45
Cees Haringa
CeesH is on a distinguished road
FLUENT can give you the wall nusselt number directly; you can visualize it with contour plots or find it under reports. DO note that this is the local Nusselt number, you have to area-average it if you want a value representing a larger wall section.
ramakant likes this.
CeesH is offline   Reply With Quote
Old   September 5, 2017, 05:42
Ramakant Gadhewal
Hi..
Thank you i am trying to go this...How can i do this area-average in surface integral ?
Old   September 5, 2017, 07:06
Cees Haringa
reports -> surface integrals
Old   September 5, 2017, 07:51
Ramakant Gadhewal
Thank you for your reply
But it is coming not correct result.
Old   February 13, 2018, 02:21
Smile hi
pankaj sharma
pankajadgjmp is on a distinguished road
hey i am working on the same stuff, but unable to figure the accurate nusselt no. please let me know if you have a solution.
pankajadgjmp is offline   Reply With Quote
Old   March 27, 2018, 08:32
vidyadhar
vidyadhar is on a distinguished road
Hello Cees,
I have an array of conductive fins attached to a constant temperature hot plate losing heat to surroundings.
Here, the temperature of the fin varies along its length as it loses heat to surroundings.
I want to plot variation of Nu along the length of one fin.
Then to calculate local Nu along the length of the fin, what are the available options in Fluent. Does the "Plot-->WallFluxes--->Surface Nusselt Number" gives the right values?
Length of the base plate which is many times larger than that of the fin is taken as reference value for length.
Thanks in advance!
Oula likes this.
vidyadhar is offline   Reply With Quote
Old   February 26, 2019, 08:37
Oula
Oula is on a distinguished road
Hi CeesH
Can Fluent give Nu as a single value?. Another thing, I can't find "Surface Nusselt Number" in the surface integral. I did a transient simulation do you think that I need to set this parameter in advance before commencing the solution?
Your help will be greatly appreciated
Oula is offline   Reply With Quote
Old   February 26, 2019, 09:56
Oula
Originally Posted by vidyadhar View Post
Hello Cees,
Thanks in advance!
Hi vidyadhar,
Did you manage to solve your problem? can you share your experience here?
Did you saved data of "Wall Fluxes" & "Surface Nusselt Number" first before starting the solution?
eagerly awaiting your reply
Old   February 26, 2019, 11:47
Oula
Hi again
I just got this information and I would like to share it here for any future visitors
To get access to the Surface Nusselt Number you need to have the following set:
1) In the Run Calculation Task Page (where you set the number of iterations), ensure you toggle on the Data Sampling for Steady State Statistics under the Options section (there is an equivalent one for Transient simulations).
2) When plotting values, you will find the variable under Unsteady Wall Statistics and then Mean Surface Nusselt Number.
If Data Sampling for Time Statistics is enabled in the Run Calculation Task Page, ANSYS Fluent gathers data for time statistics while performing the simulation. The statistics that ANSYS Fluent collects at each sampling interval (which consists of the mean and the root-mean-square-error (RMSE) values) can be postprocessed by selecting Unsteady Statistics... in any of the postprocessing dialog boxes. If you select Unsteady Wall Statistics... in any of the postprocessing dialog boxes, you can view wall statistics such as Mean Pressure Coefficient, Mean Wall Shear Stress, Mean X-Wall Shear Stress, Mean Y-Wall Shear Stress, Mean Z-Wall Shear Stress, Mean Skin Friction Coefficient, Mean Surface Heat Flux, Mean Surface Heat Transfer Coef., Mean Surface Nusselt Number, Mean Surface Stanton Number.
Important: When including or excluding statistics on variables, it is recommended that you re-initialize the flow statistics.
Old   May 8, 2019, 04:00
vidyadhar
Hi Oula,
I have done like this
Local heat transfer coefficients can be plotted on any surface of interest using Plot--->Wall Fluxes-->surface heat transfer coefficient.
Regards,
vidyadhar
calculate friction factor & nusselt number soheil1991 FLUENT 3 March 11, 2017 09:30
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Extracting Average Nusselt Number of a vertical Solar Chimney directly from Fluent yomilayeni FLUENT 11 September 23, 2015 16:12
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
