September 18, 2017, 08:05 |
symmetric flow problem
Rep Power: 10 |
Hi, I simulate a combustion chamber with 8 swirl burners. I wrote a profile from another, older domain and interpolated the velocities succesfull to the 8 burners in the new domain. The inlet velocities of the burners look very good. But for some reason, the turbulence is not correct even though I typed in constant values. Every burner should be exactly the same. Some of the burners are perfectly correct, some of them do not have a swirl. Does anybody know, why this is happening?
I use a Hexa non-conformal mesh and Fluent 17.2 Greetings Sufjanst |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
A problem of incorrect fluid flow field using Openfoam | marialhm | OpenFOAM Running, Solving & CFD | 25 | June 12, 2017 02:34 |
Back flow problem in gas cyclone | lakhi | FLUENT | 0 | August 31, 2012 04:27 |
Periodic flow boundary condition problem | sudha | FLUENT | 3 | April 28, 2004 08:40 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
