[Sponsors] | |||||
Jeff Yam
Rep Power: 10 ![]() |
I am currently simulating 2D asymmetric flow in a ejector using R134a as the working fluid.
I am trying to figure out the mass flow rate for the inlets and outlet for the working fluid. Currently, i am just using the velocity x density to manually calculate the mass flow rate which i find troublesome. The monitor surface options seems to be missing when i am running the simulation in 2D, any help on this? |
ali
Rep Power: 11 ![]() |
[QUOTE=NozzleNoobie;664554]I am currently simulating 2D asymmetric flow in a ejector using R134a as the working fluid.
I am trying to figure out the mass flow rate for the inlets and outlet for the working fluid. Currently, i am just using the velocity x density to manually calculate the mass flow rate which i find troublesome. The monitor surface options seems to be missing when i am running the simulation in 2D, any help on this?[hello my friend. for monitoring the mass flow rate in ejector you should act as below: solution----monitors----------surface monitors---------] and then choose these options according the below image: |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| boundary condition with pressure AND mass flow rate | tsi07 | FLUENT | 3 | April 14, 2022 13:32 |
| Higher mass flow rate at outlets as compare to inlet | Ahmed Saieed | FLUENT | 0 | April 4, 2016 00:08 |
| trying to perform accurate mass flow rate sampling through hot-film probe | UTA_ARC | ANSYS | 0 | December 2, 2015 14:20 |
| Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 19:11 |
| mass flow rate in DPM steady tracking | Roule | FLUENT | 4 | June 1, 2015 11:44 |
