[Sponsors] | |||||
Lucas Barreto
Rep Power: 10 ![]() |
Hi guys,
I am simulating the flow over an aircraft wing. I am able to easily get the pressure contour plot on my wall. I were wondering if ansys would be able to give the pressure value on each cell on my wall? Like a (x,y,z) vs Pressure. I know I can get this manually with the probe but is there any way to do it automatically? Thanks in advance. |
Lucky
Rep Power: 68 ![]() ![]() ![]() |
Go to File=>Export=>Solution Data and choose the surface & choose pressure as the variable to export. You also have the choice of node values vs "cell" values. You can write ascii tables and so forth. You can easily read the ascii table into excel or matlab, etc.
Note that if you forget to select a surface, it will write all the pressures in the entire cell zone. |
#3 | |
Lucas Barreto
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 13:23 |
| "Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 11:08 |
| Setting up the pressure variation due to tornado in a duct(UDF)+animation | guillaume1990 | FLUENT | 0 | March 3, 2014 12:59 |
| Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 14:45 |
| Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
