October 4, 2017, 14:59 |
again natural convection
saba
Rep Power: 8 |
Please, no one help me , Previously I send my problems but there is no answer
I need help My Problem is to study the natural convection in cylindrical tank containing coiling pipe working as a heat exchanger (like shell and tube) but the cylindrical tank containing hot water with a different temperature start from 70oC end to 90oC with increment 5oC all the tank walls insulated and the bottom wall there are three heater 6000 watt in order to heat the water with one replay heater in order to get the required bath temperature and get heat to the coiling that carrying cold water first get the geometry subtract the tank from coiling pipe because I need to study natural only on the tank second mesh with coarse grid because medium didnot give me solution third boundary conditions if I enter all the tank boundaries insulated with heat flux on coiling wall range from 1e5 to 4e5 Ididnot get solution only if take coupled solution with body force solution for pressure with pseudo time I get solution but continuty with x-velocity y-velocityand z-velocity remain flactuated 10e-2 please I need your help to complete my research I work in it 3 months if my modeling is incorrect what you are advice me thanks |
October 9, 2017, 20:49 |
Alexander
Rep Power: 34 |
What is the problem with your case, I gave no information
October 28, 2017, 11:15 |
saba
Rep Power: 8 |
first get the geometry subtract the tank from coiling pipe because I need to study natural only on the tank second mesh with coarse grid because medium didnot give me solution third boundary conditions if I enter all the tank boundaries insulated with heat flux on coiling wall range from 1e5 to 4e5 Ididnot get solution only if take coupled solution with body force solution for pressure with pseudo time I get solution but continuty with x-velocity y-velocityand z-velocity remain flactuated 10e-2 |
Triggering turbulence in natural convection | agustinvo | Main CFD Forum | 8 | November 8, 2016 02:33 |
Thermophysical properties for natural convection | Ciefdi | OpenFOAM Running, Solving & CFD | 0 | November 7, 2013 11:44 |
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 09:26 |
Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 04:58 |
natural convection at high Rayleigh | mauricio | FLUENT | 2 | February 23, 2005 19:43 |
