-   FLUENT (https://www.cfd-online.com/Forums/fluent/)
-   -   display report plots (https://www.cfd-online.com/Forums/fluent/194231-display-report-plots.html)
gerritb October 11, 2017 22:27
Hi all,
I want to display average temperatures of different volume regions of my model over the calculation iterations (its a steady state analysis). Therefore I created a report plot and a report definition for each volume area. While running the calculation, the plot was displayed properly.
However, after closing the plot window I couldn't find an option to display the plot again. For the residuals (that are also displayed during calculation) I just have to double-click the 'residual' button under 'monitors'. This doesn't work for the report plot though.
Thanks!
Gerrit
MKuhn October 12, 2017 02:00
Solution - Monitors - Volume
Hi Gerrit, in FLUENT on the left go to Solution \rightarrow Monitors \rightarrow Volume. Than create for each of your volumes a Volume Monitor and choose under option "write" and define a File Name (different for each volume) and Folder. You can view this files with any text editor or import it to Excel to create graphs, even during the calculation.
Hopefully that will help.
Cheers Moritz.
gerritb October 12, 2017 20:09
Ok, thanks a lot for the advise.
But there is no way to simply bring the plot display back to FLUENT?
MKuhn October 13, 2017 01:42
Sorry no idea, maybe not.
gerritb October 18, 2017 05:24
After the simulation is finished the files can be read into Fluent and displayed as a simple x-y plot. This resolves my problem.
Thanks for the idea with writing the data into files!
ebtedaei October 17, 2018 14:45
This is also my problem! Please help me.
Thanks
esha May 10, 2019 13:44
problem runing fluent in batch mode
Hi, I am runing fluent 19.1 in batch mode for flow over circular cylinder and want to have report file of Cd and Cl. I have these files on runing fluent on my desktop but in batch mode I did not get these files and it do not show any option to give it the path of cluster file. How may I have these in batch mode?
LuckyTran May 10, 2019 14:50
The path is specified when you create the report. If you have the right path specified, and Fluent can write to that path, it will. Just check your case file.
esha May 11, 2019 00:30
[img]https://imgur.com/a/crq5xNM[img]As I am unable to upload a picture here so, I uploaded its path. please have a look at it.
It allows me to link path for saving data but not for saving report file as shown in the circle. is there any solution for this? I have spent a lot of time for searching a solution to this.
krndv January 12, 2020 23:55
Just click calculate button again
Just click the calculate button again and stop after 1 iteration. It will show all report plots.
cons013 July 22, 2022 11:39
THANKYOU this fixed my solution not updating issue. However it won't show all plots from the beginning, it might only show one iteration.
