Problem to solve T8 cascade test
Old   October 16, 2017, 13:19
Question Problem to solve T8 cascade test
Ana Adalgiza
ana_aa is on a distinguished road
Hello, I'm trying simulate a T8 cascade test in Fluent, but the shock wave is dissipating in fluid who causes the maximum Mach number lower than expected.
The boundary conditions who i used are:
-Inviscid flow;
-Energy is on;
-Steady state;
-Pressure inlet: 43.842 Pa;
-Temperature: 292 K;
-Pressure outlet: 23.080 Pa;
-Periodicity in the blade channel;
-Operating Conditions: 0 Pa.
In the solver i used density-based, in the solution method i tried to use implicit-AUSM. The spatial discretization in gradient is setted as Least squares cell based. Initially, i run calculation to the flow as first order upwind and when the solution is converged i changed that to the second order.
The mesh was checked and the quality is ok! I used the same mesh and case to an in-house program (this program is validated) and i obtained a good resolution of shock wave.
Can someone help me?
Thanks everyone,
Ana
ana_aa is offline   Reply With Quote
Old   October 17, 2017, 02:46
Jaesan Yoon
litzj is on a distinguished road
picture might be help to figure out problem.
did you use same mesh for the two solvers?
how about adapt mesh near shockwave
litzj is offline   Reply With Quote
Old   October 19, 2017, 20:36
Ana Adalgiza
I'm working as a Turbine. I used the same mesh in both solver. I did not try to use the adaptative mesh.
In picture shown what is happening.
euler, resolution, shock wave
Which multiphase flow to solve this problem? mariam.sara Fluent Multiphase 3 May 4, 2014 11:04
how to solve a problem involving both laminar and turbulent flow seefd FLUENT 1 June 3, 2011 03:20
Could CFX solve hydraulic jump problem? Andy Chen CFX 0 August 18, 2009 10:13
Can I use fluent to solve this multiphase problem Steven FLUENT 1 January 24, 2003 20:52
Can FLUENT solve this type of problem? Whitaker FLUENT 3 October 23, 2000 03:01
