30+ hours for 300k nodes
Old   October 31, 2017, 08:29
Default 30+ hours for 300k nodes
Xilef Smith
Springroove is on a distinguished road
Hi all,
I am working on a problem comprising a train travelling in an evacuated tube at 300 m/s (M=0.88). However, it takes about 30+ hours to reach about 10,000 iterations which is not even convergence. Does this maybe have to do with my boundary conditions? (I only have 300k nodes and the full domain is 200m x 0.1m)
I've tried different bc's but to no avail. For the latest run I have the following bc's:
Inlet velocity u = 300 m/s and total temperature of 300K
top, bottom and side walls all moving with 300 m/s in x-(flow)-direction
outlet pressure of 100 Pa (which is the ambient tube pressure)
the train is just a no-slip wall
I'm using the SST model
I don't think it's due to my workstation as I am using a laptop which has i7 @2.2 GHz with 16GB RAM.
Cheers!!
Springroove is offline   Reply With Quote
Old   October 31, 2017, 08:44
Jaesan Yoon
litzj is on a distinguished road
I do not know Mach # of this case, but it seems that compressibility should be considered...
If you do not correctly mesh for near-shock region, vibrated shock position interrupt your convergence.
litzj is offline   Reply With Quote
Old   October 31, 2017, 09:56
Xilef Smith
Thank you for your answer.
Do you maybe know some tutorials or examples where I can find things related to these boundary conditions?
I was wondering whether it might be due to the imposed velocities and the outlet pressure.
Cheers
SIMPLE algorithm SamR Main CFD Forum 19 April 26, 2019 13:06
32 Cores Mini-Cluster, 2 Nodes vs. 4 Nodes performance Courageous Hardware 3 July 7, 2016 11:37
F_NNODE returns double number of nodes falkon Fluent UDF and Scheme Programming 0 March 8, 2014 06:58
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
