Home > Forums > FLUENT
Energy residual changing between two values
Old   November 2, 2017, 10:34
Default Energy residual changing between two values
Foxhunter is on a distinguished road
Hello all,
I am simulating combustion in a flare. For this I am using the transient solver, the solution has a hard time converging in the steady state solver. But here is the problem: My energy residual keeps switching between two values. If I change the timestep the values change, but it still switches between two values(so for a timestep of 1e-5s it switches between 1,311e-4 to 3,843e-4 and with a timestep of 1e-6 it switches between 1,423e-5 to 4,562e-5). If I reduce the residual far enough (0,5 or lower) it gets stuck on one value. How do I solve this?
Thanks!
Foxhunter is offline   Reply With Quote
Old   November 2, 2017, 12:45
flotus1's Avatar
Alex
flotus1 will become famous soon enoughflotus1 will become famous soon enough
Are you sure that you are not just seeing the normal convergence behavior of a transient simulation? High residuals at the beginning of a time step that are then reduced to lower values during the inner iterations...
Please do not send me CFD-related questions via PM
flotus1 is offline   Reply With Quote
Old   November 3, 2017, 02:13
Maybe... I'm just wierded out because it starts jumping between two values after some iterations. For each timestep the same values!
Old   November 3, 2017, 04:52
flotus1's Avatar
Alex
You can upload a screenshot if you want.
Until then I suspect the residuals look like this.
Old   November 3, 2017, 05:01
If only...
It converges a little bit, and then it starts changing between the same two values in one timestep. So basically it starts to oscillate between two set values untill the maximum iterations/timestep is reached. And then it does it again for the next timestep.
Old   November 3, 2017, 05:33
flotus1's Avatar
Alex
A picture is worth a thousand words...
Old   November 3, 2017, 06:09
It looks worse than it is. The first few timesteps look like the image you uploaded, it became so irregular after the spark ignition kicked in. I could not replicate the "jumping between two set values", but this is definitly how it looked. What do you think?
Old   November 3, 2017, 06:26
flotus1's Avatar
Alex
Looks fine to me. The time step size might be too high which causes a high level for the continuity residual and poor convergence in general.
Old   November 3, 2017, 06:28
I tried decreasing the time step to 1e-8... Even then it does not converge good. I also changed the relaxation factors, no joy there either. Maybe it's so unstable that normal convergence cannot be achieved?
Thread Tools
Trackbacks are On
Suppress twoPhaseEulerFoam energy AlmostSurelyRob OpenFOAM Running, Solving & CFD 28 November 10, 2017 16:45
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 05:49
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
