Piston profile for ICE Cold flow simulation |
August 8, 2016, 07:23 |
#1 | |
Adil Syyed
Rep Power: 13 |
In cold flow simulation, the user is required to make a valve lift profile in the form of a *.prof file corresponding to different crank angles. I already made mine and it works like a charm. No problems there.
But, according to ANSYS documentation, Quote:
Note: By default ANSYS Fluent assumes 0 crank angle at TDC and starts simulation from there. |
August 21, 2016, 22:13 |
Michael Feng
could you share your profile file, because I don't quite understand the matrix for angle and lifting settings.
August 22, 2016, 13:46 |
#3 | |
Adil Syyed
Rep Power: 13 |
You can get a detailed explanation of the valve lift profile file on https://www.sharcnet.ca/Software/Ans...setup_ice.html If you still need the profile file, let me know. |
October 12, 2016, 05:31 |
#4 | |
Adeoye Lukman
Rep Power: 9 |
October 19, 2016, 03:08 |
#5 | |
Adil Syyed
Rep Power: 13 |
I would share my lift profile and corresponding graph of piston motion when I can (Not at home right now). But it you can explain your problem, I could guide you better. |
October 22, 2016, 11:19 |
Adil Syyed
Rep Power: 13 |
This is for your understanding only. Every engine has its own valve lift and corresponding crank angles. If you have any question, feel free to ask.
PS: Rename lift.txt to lift.prof or anything_really.prof |
October 23, 2016, 06:35 |
Concerning the valve lift and piston motion profile
Adeoye Lukman
Rep Power: 9 |
Thanks for your reply. I'm very grateful. I've tried the format you sent to me. Please will the profile contain both the graph and the text format. The error that always proped up was that "valve lift are at zero,check the valve lift profile format".
Thanks very much for your timely reply. Is it possible for me to have your what's app contact. Thanks. |
October 24, 2016, 14:47 |
#8 | |
Adil Syyed
Rep Power: 13 |
Have you given valve lift values in your prof file? As I said in earlier post, rename the text file to .prof The format for valve lift profile is .prof You can make your file as text file in notepad and then rename it as .prof file. But remember that the .prof must be the format or extension of the file, not the name. Sometimes the extension .txt is hidden and we endup renaming the file instead of the extension; in which case it would become lift.prof.txt which is still a text file. If you are facing difficulty renaming the file, just follow step by step instructions at http://www.mediacollege.com/microsof...on-change.html |
November 19, 2016, 03:41 |
#9 |
Adeoye Lukman
Rep Power: 9 |
I'm very sorry for the late ackwnoledgement of your previous conbtribution.
Thanks very much for your contribution all this while. Really appreciated. Please I have a very tough challenge with my geometry, I have model my geometry more than 10 times but all could not give the desired result.so many amendments has been made all to no avail. Please I won't mind if you can assist in this regard by sending the geometry that was used in the ansys tutorial if you have.Thanks for your usual cooperation. |
November 28, 2016, 09:41 |
#10 | |
Adil Syyed
Rep Power: 13 |
What problem do you face? Specifically, 1. The FLUID PART of the intake/exhaust ports need to be modeled. 2. The SOLID PART of the intake/exhaust valve need to be modeled. 3. The FLUID PART of the of the cylinder needs to be modeled. 4. The piston is not modeled. The whole geometry is then decomposed at a certain crank angle (say intake valve opening crank angle), which then helps in dynamic meshing of the geometry. |
December 20, 2016, 01:20 |
#11 |
Adeoye Lukman
Rep Power: 9 |
Good morning thanks for your contributions all this while.
Please I'm encountered some challenges of recent. I have started the simulation, I'm at the calculation stage at about 360 crank angle starting from 323.25 the simulation stops.it brought an error saying no current activation, it complain about the journal and specifically it complaints about the temperature. I'm using 4gb,64-bit,core-i3 for the simulation. Please could this be as a result of hardware problem. And what is the minimum hardware requirement for cold flow simulation. Thanks in anticipation of your reply. |
October 21, 2017, 05:10 |
#12 |
BIBU B
Rep Power: 8 |
is it contain piston profile also or do we need to create separately and merge with the valve profile
February 5, 2018, 22:18 |
diesel engine simulation guide
#13 |
SANUSI AKINTUNDE
hi guys, i'm current working on diesel engine and i need guide on generating my profile files myself. the geometry, valve and injection profile and others for a full engine simulation.
April 24, 2018, 22:03 |
#14 |
YKuenday
how do I get this information? the valve lift and crank angles for the engine?
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Pipe Flow Simulation | comingdaytime | OpenFOAM Running, Solving & CFD | 3 | July 27, 2016 10:40 |
Cold Flow on Partially premixed combustion | dvd91 | FLUENT | 0 | May 7, 2015 17:04 |
how to get a time-accurate solution in Flow Simulation | drdet | FloEFD, FloWorks & FloTHERM | 4 | January 20, 2015 07:11 |
mass flow rate issue in supersonic nozzle simulation | xkang | FLUENT | 0 | July 31, 2014 16:06 |
