November 8, 2017, 15:54 |
Fluent 18.1 F1 process Bug?
Rep Power: 9 |
I tried to make this simulation:
https://www.youtube.com/watch?v=l8cqntjoaaI A simulation of many iterations, over 100000. All time steps convergate, but over 20000 iterations, fluent crashes with an F1 Error: The F1 process could not be started. Whats wrong? I tried it on two different computers with winx64 10. The same problem. Over 20000 iterations, fluent crashes. The fluent handler/task close abruptly. What means with the F1 process? Is that a bug on the consumer version? Thank you |
November 9, 2017, 05:12 |
Baris PULAT
Rep Power: 9 |
From what i see Fluent processes terminated or an interruption happened.
Can you add exceptions for Fluent in your security software and rerun the simulation. You can also use of a local loopback IP address when starting Fluent by adding the FLUENT_HOST_IP=-127.0.0.1 to the FLUENT Launcher Environment tab. |
November 9, 2017, 12:53 |
Rep Power: 9 |
Ok, i turned the gpu acceleration off and the simulation runs with over 100000 iterations in double precision mode.
I am to retry that with a parameter of geometry. And fluent process terminated again, ~ 65000 iteration. I will try now without security software. Can it be a bit error of non ECC-RAM? |
November 10, 2017, 03:22 |
Baris PULAT
Rep Power: 9 |
Hmm i heard people complaining about non ECC-RAMS.
Can you run a test with stressapptest if you didn't. |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
On Bug of Fluent 12.0 | lzgwhy | FLUENT | 0 | August 26, 2009 06:41 |
Error in Fluent. Gamma = 1.4------- Bug | a | FLUENT | 2 | May 9, 2008 17:21 |
Modelling Sintering Process with Fluent | Saeed | FLUENT | 0 | October 20, 2007 06:56 |
spwaning process problem in parallel fluent urg! | Nabeel | FLUENT | 0 | October 5, 2005 02:22 |
