Lift and drag coefficients for a vertical axis wind turbine |
November 14, 2017, 07:10 |
Have a nice time!
Rep Power: 11 |
Hello, If we have a rotating VAWT, and if we selected an airfoil which rotates by a specific speed, and monitor the lift and drag coefficient in Fluent, and the force vector of the lift is at y and its value is 1 like the attached snapshot, will the lift coefficient be accurately calculated during the rotation of the airfoil because the angle is changed and the force vector is still in y direction?
Thanks |
February 1, 2018, 16:12 |
Rep Power: 8 |
Hi Ahmed
Did you figured out the answer for this question? |
February 3, 2018, 19:31 |
Have a nice time!
Rep Power: 11 |
Yes dear Samir, using sliding mesh technique already tells Fluent that the cells will rotate and at every new position, the new lift and drag forces are calculated according to the new position of the rotor cells, I have showed how to get these curves on my tutorial on youtube ..It is a tutorial about a 3D VAWT, I was asked that question and I found what I have just typed...
Thanks |
February 4, 2018, 05:25 |
Rep Power: 8 |
Thank you dear Ahmed
By the way do you have an idea about the same issue in OpenFOAM. Is it the same?
"When in doubt, use brute force." -- Ken Thompson |
February 4, 2018, 09:22 |
#5 | |
Have a nice time!
Rep Power: 11 |
Thanks |
Lift and drag coefficients of the NACA 0018 | Volodymyr | CONVERGE | 4 | September 22, 2017 17:52 |
drag and lift coefficients in axisymmetric and 3D simulations! | CFD-Lover | OpenFOAM Running, Solving & CFD | 0 | July 1, 2017 16:33 |
3d wind turbine lift drag | smarika | ANSYS | 0 | December 3, 2014 09:33 |
Modeling a rotating vertical axis stream turbine | VIMeerkat | FLUENT | 0 | February 11, 2013 13:03 |
Lift and Drag Coefficients Reliability | Luis | FLUENT | 2 | December 27, 2005 14:45 |
