MHD Fluent Simulation of Magnetorheological Fluid in annular gap.
Old   July 13, 2015, 05:48
Default MHD Fluent Simulation of Magnetorheological Fluid in annular gap.
Dr Gurubasavaraju
gbrajtm is on a distinguished road
Hi all,
I was trying to simulate MHD for finding the velocity profile of flow in the gap under different magnetic field.
Dimension = length 40 mm height= 1.5mm
Magnetic field region = 5mm to 35 mm
Pressure inlet- 500pa
outlet - 0 pa
material - MR fluid
visco = 0.09 pas
permeability= 0.0008 H/m
Density= 3180 Kg/mm3.
i did simulation for 3T magnetic flux. But the velocity profile looks abnormal, velocity not reducing in the magnetic region, reduces only are the terminals of the field. Could any body please help me to find the profile.
gbrajtm is offline   Reply With Quote
Old   November 18, 2017, 02:43
nazar
nazar1979 is on a distinguished road
hello
are you solve this problem. please help me?
nazar1979 is offline   Reply With Quote
Setting an external B0_x field in MHD module fferroni FLUENT 11 August 1, 2022 08:20
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
variable density in single fluid simulation not running with total energy viking CFX 2 September 18, 2012 20:19
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 Mohammad Al-Shannag Main CFD Forum 1 July 16, 1999 11:28
