create rectangular bounded plane
Old   November 19, 2017, 10:43
Default create rectangular bounded plane
Yu Lu
yulu is on a distinguished road
Hi all
I want to create a bounded rectangular shape 2-D plane to view to results at this plane, when I chose the 'bounded' option in the plane surface window it let me choose three points then a triangle shape plane is created.
How can I create a rectangular plane??
Thanks!
yulu is offline   Reply With Quote
Old   November 19, 2017, 19:55
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
If your plane is orthogonal to main axis than it is very convenient to use iso-surface to create plane.
Go to new-surface->iso-surface->mesh->choose axis->select body you want to slice in zones-> put coordinate value
Do not forget to initialize your case first
Best regards
AlexanderZ is offline   Reply With Quote
Using a Plane id in Fluent UDF cdf_user Fluent UDF and Scheme Programming 13 October 17, 2023 00:06
create plane zeinab Mesh Generation & Pre-Processing 0 May 12, 2016 04:22
how to create a sampledPlane from a finite plane Ya_Squall2010 OpenFOAM Running, Solving & CFD 0 June 4, 2014 02:18
[DesignModeler] How to create rectangular enclosure for ventilation analysis sa_appu ANSYS Meshing & Geometry 0 August 11, 2012 00:08
How to create plane coutte flow by using LBM? TSYen Main CFD Forum 0 September 9, 2004 05:24
