Problems with layering at moving boundaries
2 Attachment(s)
Hello!
I'm working on a case similar to a cilindrical dam opening gradually with constant velocity and 2D geometry. The mesh and boundary conditions are displayed at figure 01. At first, I attached a CG_MOTION UDF for the boundary condition "moving wall" and "pressure outlet" at the top; that way, the walls of the dam would follow the movement of both boundary conditions (moving wall and pressure outlet) and it would open. The UDF used: #include "udf.h" #include "dynamesh_tools.h" //static real max_disp = 0.004; //static real velocity = 0.1; DEFINE_CG_MOTION(movingWall,dt,vel,omega,time,dtim e) { NV_S(vel,=,0.0); NV_S(omega,=,0.0); static real x0 = 0.001; // meters static real velocity = 0.1; real x; if (!Data_Valid_P()) return; //vel[0] = -velocity*pow(-1, (int)floor(time / (max_disp / velocity))); if (time == dtime) x = x0 + velocity*dtime; else x = x + velocity*dtime; Message ("Info: updating position x = %f, and velocity v = %f.\n", x, velocity); //vel[0] = velocity; vel[0] = 0.1; } Since i'm using a rectangular mesh, i choose the layering technique for the dynamic mesh. But i'm experiencing some problems as it follows at figure 2. The mesh isn't relayering and i got a negative volume error. Could somebody help with this problem? If i wasn't clear at my questions, please ask me. Thanks in advance! Yuri Taglieri |
