[Sponsors] | |||||
Rep Power: 10 ![]() |
Hi Guys, really hope you can help me.
![]() I am working on a 2D based Savonius VAWT which is a drag based torque generation device. My issue is that as I increase tip speed ratio, power generation climbs exponentially to efficiencies above the 59% betz limit, also, literature shows that Savonius VAWTs typically don't have efficiencies higher than 30%. I am currently using the K-ω SST model as all the journals say this is better for separated flows. My air values are as standard from ansys fluent. Has anyone got any past experiences with a problem like this? My task is to optimize the design of a NACA 7715 Savonius VAWT, pitch angle, no. of blades etc. and it will be used in a VAWT cluster later in my studies. Thanks for any help!!
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Vertical Axis Wind Turbine (VAWT) verification | bahieu | STAR-CCM+ | 6 | March 18, 2020 06:32 |
| Need to output surface pressure on blades in a vertical axis wind turbine | kmallick | OpenFOAM Post-Processing | 1 | October 22, 2018 00:08 |
| High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) | tony00 | FLUENT | 11 | July 23, 2018 07:13 |
| Vertical Axis Wind Turbine (VAWT) simulation | Jorge22 | CFX | 5 | November 18, 2017 06:18 |
| Vertical Axis Wind Turbine | atorninc | Main CFD Forum | 3 | March 6, 2013 05:38 |
