December 13, 2017, 07:26 |
TUI Inputfile - Fluent would skip some lines
CWL
Rep Power: 10 |
I wonder if anyone can shed some light on the following. For some reason, Fluent would not write the output files at the end of the simulation. It would always skip the lines file/write-case and file/write-data. I am wondering what could be the reason. Thanks. file/read-case Small-Case.cas.gz file/read-data Small-Case.dat.gz file/auto-save/data-frequency 50 file/auto-save/root-name Small-Case.dat.gz solve/set/flow-warnings no solve/set/time-step 1.e-3 solve/dti 2025 20 file/write-case Small-Case-Final_%t.cas.gz file/confirm-overwrite yes file/write-data Small-Case-Final_%t.dat.gz file/confirm-overwrite yes exit yes |
December 15, 2017, 17:49 |
Lucky
Rep Power: 65 |
file/confirm-overwrite yes/no is an option to ask for user confirmation, it does not answer the yes/no
you need to do something like: file/write-case Small-Case-Final_%t.cas.gz ok |
December 17, 2017, 08:43 |
CWL
Rep Power: 10 |
Thanks for your suggestion. I changed the line, however, the write out lines are still skipped - there are still no output files being written for some reason.
December 19, 2017, 15:39 |
CWL
Rep Power: 10 |
Thanks LuckyTran for point that out. Actually, I realized the user confirmation should not be asked in the first place since it is write to a new file. Indeed, 4 yes are supposed to be included at the end of the solve/dti line. The software went ahead and did what it should have done without the four yes caused the oversight. I saw the halt due to end of input file message after reading the reply and figured out what could have gone wrong. Thanks and Merry Christmas.
Problem in compiling fluent UDF lunched from MATLAB | cfdman10 | Fluent UDF and Scheme Programming | 16 | December 5, 2019 05:32 |
change default path of result file using TUI in fluent | jumaah | FLUENT | 3 | May 27, 2017 21:04 |
Fluent TUI command, How to do it? | Ash Kot | FLUENT | 2 | October 17, 2016 13:42 |
TUI to replace mesh in fluent 16 | Jelos.ch | FLUENT | 0 | November 29, 2015 16:24 |
Error with FLUENT TUI transient-export function | DarrenC | FLUENT | 0 | March 14, 2011 17:30 |
