[Fluent meshing] Create fluid domain + BOI automatically
Old   August 4, 2021, 09:30
Question [Fluent meshing] Create fluid domain + BOI automatically
jbt
jbt is on a distinguished road
Hi all,
I plan to use Fluent meshing to generate meshes with a high level of automation, but I don't currently know which possibilities are offered by this software. As of now, I generate geometries or clean up CAD using Spaceclaim. Said geometries are then injected into Fluent meshing through the Workbench pipeline interface. This process can be done on my professional laptop.
For more complex geometries and much bigger meshes, I would like to automate this workflow on my company's cluster. But here's the catch: Workbench is not available on the supercomputer, which means that I do not have access to Ansys meshing or Spaceclaim, only Fluent (and hence Fluent meshing) is available. The CAD files that I usually receive from my colleagues only contain the geometry, but not the fluid domain nor the bodies of influence that I have to create manually using Spaceclaim.
Is there a way to generate these using Fluent meshing?
jbt is offline   Reply With Quote
automation, boi, cad, fluent meshing
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Periodic Pressure drop cfd_begin CFX 10 May 25, 2017 07:09
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
