December 27, 2017, 14:00 |
Subsonic compressibe flow
Mahdev Prasad Panda
Rep Power: 8 |
Hy
I am trying to do a simulation which involves subsonic compressible flow.I am a bit of a beginner in fluent.can anyone tell me what kind of solver should i use pressure based or density based?? |
December 28, 2017, 01:07 |
Kirill Borodin
Rep Power: 10 |
Hi! Use density based for compressible flows
December 28, 2017, 06:05 |
Mahdev Prasad Panda
Rep Power: 8 |
Thank you
I did that. I have the inlet velocity and I want to check outlet pressure what boundary conditions should i use to get a better convergence??? And can I use laminar flow for this kind of set up?? |
December 28, 2017, 13:10 |
wasim
Rep Power: 10 |
For Nozzle flow always specify pressure as boundary conditions....so specify inlet and outlet pressure condition to check Mach No. along nozzle axis.....
December 28, 2017, 16:39 |
Mahdev Prasad Panda
Rep Power: 8 |
Thank you
actually i am trying to do a simulation for a compressor. The flow is highly subsonic but the density is changing.Can you tell what boundary conditions would be appropriate for these kind of set up?? |
December 29, 2017, 02:15 |
Kirill Borodin
Rep Power: 10 |
Use the same static pressure and static temperature as in the inlet
December 29, 2017, 05:05 |
Mahdev Prasad Panda
Rep Power: 8 |
Thank you for helping me.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Stagnation enthapy loss in subsonic adiabatic flow using RANS CFD | renshenguoer | Main CFD Forum | 3 | July 6, 2017 02:51 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
subsonic nozzle flow, inlet-outlet BCs | felix | Main CFD Forum | 3 | May 15, 2006 10:37 |
Subsonic flow in a supsersonic nozzle | Laplacien | FLUENT | 0 | April 6, 2006 03:27 |
